No water filling ice maker on a Maytag mod.MFI2269VEM7 Ser.K21210164
Old 02-02-15, 08:09 AM
Ice maker stopped working right after warranty was up.
Water does not fill tray.Maybe something simple,unsure?
Old 02-02-15, 02:05 PM
Received 477 Votes on 447 Posts
Nothing is simple with an ice maker.
I usually start at the fill valve which is on the lower back of the fridge. An easy way to check it is since it's a double valve, door water and ice maker, is to reverse the wiring on the two valve solenoids. Now when you call for drinking water... the ice maker should get water.
You can also check both solenoids for continuity with an ohmmeter.
Old 02-02-15, 03:03 PM
Plugged up filter.
Bad solenoid on the inlet valve.
Tried repairclinic.com? If you have the model number it comes up with trouble shooting, part #'s and even video on how to replace in some cases.
Old 02-02-15, 04:50 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Is the supply line connected to a saddle valve?
Source: motorera.com
Old 02-03-15, 03:39 PM
Thanks again, I do get door water and if i fill the ice tray manually, it makes ice.
i will have to pull unit and check the wiring and continuity on the solenoids.
