Kemore 80 series Washer spin cycle works intermittently
Old 03-01-15, 12:03 PM
I have a Kenmore 80 series washer. The mod. # is 110.26882500.
It seems like the spin cycle will not work about 50% of the time. On the times that it does work it seems to work just fine. When it doesn't spin it sounds like it is.
The wash cycle seems to work fine with the agitator cycle always working as it should.
I also suspect that a small eyeglass cleaning cloth, maybe even two, have come up missing. Is it/are they stuck somewhere? In the drain perhaps?
Does one have anything to do with the other.
Thanks!
Last edited by MickyFig; 03-01-15 at 12:18 PM. Reason: To append info and add model #
Old 03-01-15, 12:06 PM
Received 3,593 Upvotes on 3,222 Posts
Welcome to the forums.
Please post the model number of your washer. It should be on the rim below the lid.
Old 03-01-15, 12:49 PM
D
Our kenmore would always spin but at times would not spin out good I believe it was according to the load wife said no. I had to install a new clutch/brake. If that is the problem and you have the manuel there is a parts list that shows them. You have to pull the cover, motor and transmision to do it . Been about 3 yrs haven't had any more problems so far.
Old 03-01-15, 01:19 PM
I don't have a/the manual any longer. I'll try to find it online. In the event it will be the clutch/brake, do you remember how much it cost?
Old 03-01-15, 04:24 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Try tightening the lid screws on the left side. Screws loosen up and will not trip lid switch. PJ model #is 110.26882500
Old 03-01-15, 05:10 PM
D
I believe the parts was less than $50.00 but I did not order from sears. I bought the parts from A to Z a local appliance part store. I don't know if they are nation wide. You can go to the sears web site and get the parts list. Our washer is about 15 years old. If that is your problem I looked on searspartsdirect.com and they have them. I thinkl I got the clutch band kit and the washer clutch assembly. You can get the hold assembly together but it is over a $100.00. I also put a new seal in the transmission on the motor side it was a little damp while I was doing it. Ours was spinning slow after I fixed it slings clothes up the side.
