Maytag oven
Old 03-06-15, 04:32 PM
Geochurchi's Avatar
Received 73 Votes on 69 Posts
Maytag oven
Hi All,Maytag oven mdl# MER 7662XX 1 will not maintain correct temperature either it over shoots or never reaches setting.
Geo
Old 03-06-15, 04:46 PM
Received 1,113 Votes on 1,033 Posts
I'm guessing you meant..... MER7662WW1.
Since it overshoots that tells me that you have a temperature sensor probe issue. With an ohmmeter you can measure it. It can also measure ok and still be defective.
Since there is a connector behind the oven wall and another at the control board..... the problem can also lie there.
Your temp sensor probe is a W10181986. At room temperature it should measure 1080 ohms.
The following is just one of many places that sell that part. They also have a video on that page for testing the probe. Maytag Range Temperature Sensor W10181986 Repair Clinic
Old 03-07-15, 04:30 AM
Geochurchi's Avatar
Pete,your right about the WW ,I'll check that later today and see what's up,there is a means to recalibrate the temperature readings, any idea what that really does?
If anything can fail it will.
Geo
Old 03-07-15, 08:57 AM
Geochurchi's Avatar
OK,so after performing the Diagnostic checks as described in the "For the Tech" paper found on the back of the oven, everything checked out OK including the oven sensor,one thing I don't understand is what is meant by "user cooking offset"can be set between 00 and 30.
Any thoughts?
Geo
Old 03-07-15, 03:05 PM
Geochurchi's Avatar
Oven temperature: "User cooking offset"
Hi All., in the Maytag Tech Only paper used for diagnostics it mentions "user cooking offset", there is an adjustment to increase from 00(factory setting) to 30,can anyone explain what this function does?
Geo
Old 03-07-15, 04:06 PM
Handyone's Avatar
No.
You know PJ is the man on appliance troubleshooting. If it's what I think it is, the oven temperature can be adjusted by user.
I have a Kenmore Elite (Electrolux) and I know I can adjust the oven temperature +/-.
I've never had the need to do it so I didn't study the procedure. I do know it wasn't obvious. You would have to know how to program using the touch pad.
Old 03-07-15, 06:02 PM
Have you heard someone say.... this is a hot oven or a cold oven. That's where it appears that the set temperature either doesn't match the actual temperature or it does but you'd like to custom reset it. Most everything is baked at 350. If it appeared that the oven didn't respond as intended you could change it a few degrees.
You had a problem with your oven hunting or overshooting the mark. The offset adjustment won't fix that problem.
Old 03-07-15, 08:57 PM
Handyone's Avatar
Good explanation Pete about the custom reset.
The +/- I referred to is not selecting or calibrating a baking temperature, it's overriding the default values. Like I said, my oven will do this, but I can't think of why the function would be needed.
Old 03-09-15, 08:27 AM
Geochurchi's Avatar
Can the temp probe cause the temps to be either hi or low even though it tests OK?there appears to be no rhyme or reason for the temps.
Geo
Old 03-09-15, 08:10 PM
I've seen them test ok and be bad. Another member just had the same problem.
http://www.doityourself.com/forum/el...ot-enough.html
Old 03-10-15, 07:51 AM
Geochurchi's Avatar
I have ordered a new sensor,it's not that it's not hot enough some times it's to hot.very radical.
I hope this works so I can get the Warden off my back
Geo
Old 03-13-15, 01:48 PM
Geochurchi's Avatar
Maytag oven update
So I replaced the temp sensor,now when the oven is set to Preheat 200*alert goes off temp on stove reads 200* Fluke thermocouple reads 265*and by using the stove diagnostics the new temp sensor shows 250*
Is there any means to make an adjustment on the control board ie. "pots"?
Thoughts!
Geo
Old 03-13-15, 01:53 PM
There is a way to electronically shift the temperature but I don't think it shifts more than +/- 15.
Did you try setting the oven to 300 ?
Old 03-13-15, 04:23 PM
Geochurchi's Avatar
I did not try setting it over 300* only because my Fluke goes out of range,why would that make a difference ? +\- 15* might be better than nothing.
Geo
Old 03-13-15, 04:34 PM
So you set the oven to preheat which should be 200 and the temperature was actually 250 or 265?
Old 03-13-15, 04:48 PM
I don't think your temperature sensor is the problem. Here is the temperature offset adjustment.
Old 03-13-15, 04:49 PM
Geochurchi's Avatar
That's correct--------///--
Old 03-14-15, 07:48 AM
Geochurchi's Avatar
It appears that these instructions recal. The temperature sensor,based on the fact that with my Fluke thermocouple set in the oven and using the diagnostics on the oven I can get the sensor to with in 10* of the Fluke,should this method make the oven temp more accurate?
Geo
Old 03-14-15, 10:10 AM
Yes.... the actual temperature will be closer to set point.
Old 03-15-15, 10:03 AM
Geochurchi's Avatar
Still having a problem when making the adjustment as described below,if the oven is overshooting the pre heat setpoint should I be increasing setting to say that the probe is seeing a higher temp than what is actually in the oven?
Geo
  #21
Old 03-17-15, 09:50 AM
Geochurchi's Avatar
Look's like I need to replace the Control board,my question would now be,what would the P/N be for just the board,not the face plate,as most of what I see are black and white is on B/O
Thanks
Geo
  #22
Old 03-17-15, 11:45 AM
The board only comes one way.
I was cruising around.... many places have the boards... there are several finishes.
I found Sears to have a too-good-to-be-true price on the board. I'd check it out....
Range Electronic Oven Control Board | Part Number W10476672 | GUARANTEED FIT from Sears PartsDirect
  #23
Old 03-17-15, 03:12 PM
Geochurchi's Avatar
That definitely is the best price,the best price I could find was about $180.00 with core charge,can't seem to find much about the Sears part, ie. used or rebuilt only guaranteed to fit.
Just called their help number and found out it is new and maytag, and if ordered by phone I save another $10.00
Geo
