Sewer smell from new washing machine?
We had a smell issue with our last LG washing machine, now with a brand new LG top load machine we are getting the same smell sometimes when we open the top cover, I am thinking it may be the drain line but since the machine's outlet is connected above the trap under the sink and no smell coming from the drain though the sink that this has to be with the dryer itself?
Are you using a dishwasher drain fitting under the sink for your washing machine? How exactly is the plumbing arranged and the washer connected?
This photo shows an incorrect way to do it.
Sewer gas smell really only comes from one place. Since your new machine is probably connected in the same manner as your old one I'm assuming the problem is somewhere with your drain plumbing or possibly a vent problem. Can you post a picture of the drain lines under your sink?
Using your pic, the red line shows where mine is connected
You are talking about a clothes washer not dishwasher? Google washer odors and you will find pages on it. Aafresh seem to work pretty good, also thereare other products for this. Many home remendys also.
You clothes washer needs to connect to a standpipe drain or into a sink that is higher then the fill level in the machine. You may have too much water being left behind in your clothes washer.
I'm confused,
Assuming this is a cloths washer, if you connect after the trap, then you need to be sure there is another trap equivalent going back to the washing machine. Not sure of the codes, but my washer is dumping into a pipe that goes through a trap to the sewer line with a vent.
Bud
Bud
We have to use the Afresh product, too. It isn't from the drain, but just an inherent smell that emanates from the washer. You'll find the instructions in the book that came with the washer. It is normal.
Yes the manual does say to use the Afresh product, why I am surprised is the our old machine which we've had for many years only had a smell problem last year and with the exact same connection above the trap.
Have you had any other plumbing related work done in the house in the last year or so? Maybe something that was done somewhere else in the system has affected your washing machine setup.
Sewer gases due to a dry trap are usually pretty easy to identify, but depending how your home is plumbed, and where everything is in relation to your vent stack, the smell could come and go, or not be really strong.
The only way I can think of to be absolutely sure where the smell is coming from would be to disconnect the washer where the drain is currently connected, and take a good whiff from the pipe. If after it is disconnected, you dont smell anything from the pipe, but you do from the inside of the washer, you will know for sure it is the washer, in which case Afresh or another cleaning product is the solution. EIther way, you should have a stand pipe installed so the washer will drain properly.
I will work on the cleaner, I am not understanding what you guys mean by a "standpipe"? Can anyone post a pic here of one please?
