Kenmore Oasis Washer getting louder during spin
Old 03-22-15, 11:09 AM
E
I have a Kenmore Oasis washer model # 110.27062603. The spin cycle keeps getting louder and louder as time goes on. Any help where to look for problem would be appreciated. Some searches referred to clutch, but speaking with sears chat, there is no clutch on this model.
Thanks JR
Old 03-22-15, 12:47 PM
Received 3,619 Upvotes on 3,245 Posts
They are correct.... there is no clutch. Yours is a direct drive machine. No gearbox or transmission.
I'm not familiar with this machine but the only thing I can think of is the hub is going bad or a bearing. Apparently bearings are an issue. See the video and if it pertains to your machine.
youtube.com/watch?v=5uoOHTLUnVw
Parts list for machine.....
MOTOR, BASKET AND TUB PARTS Diagram & Parts List for Model 11027062603 Kenmore-elite-Parts Washer-Parts | SearsPartsDirect
This is the full size diagram that will expand when you click on the diagram. searspartsdirect.com/lis_png/PLDM/K0702018-00003.png
Old 03-22-15, 02:38 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Very common problem with your machine. Have replaced many bearings and tub assy for bad bearings.
Here is the bearing kit # W10435302. Also there is a special tool for it. A lot of times the basket is stuck on shaft and will not come off. you might call Kenmore to see if they extended any warranty's on this. Don't think they did but can't hurt to try.
