Kenmore Elite dryer doesn't heat
Old 05-10-15, 11:34 PM
E
Motor runs, no unordinary noises but it does not heat. What to do I need to do in order to fix it myself? I'm a single mother of 2 so please when replying, be detailed. Thank you ~
Old 05-11-15, 04:01 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Post model # found inside door. will look like this xxx.xxxxxxxx need all numbers. Do you have a multi meter? usually dryers easy to fix but need meter. No meter, meter can be cheap harbor freight has some less the 20$
Old 05-11-15, 12:03 PM
Received 3,610 Upvotes on 3,236 Posts
Try pushing the circuit breaker all the way to the off position and then turning back on.
