Freezer cold, Frig warm GE Model #GTS22KCPBRCC
Old 05-19-15, 01:19 PM
Freezer works, however refrigerator is not receiving cold air. Replaced the fan motor in the freezer but fan still does not turn on to blow air to the refrigerator. Not sure what else to check/replace. Any suggestions?
Old 05-19-15, 05:39 PM
Received 126 Upvotes on 111 Posts
Should have checked the voltage with a volt OHM meter before changing the fan, no voltage, not going to work.
Check out repairclinic.com
Old 05-19-15, 06:36 PM
Received 3,619 Upvotes on 3,245 Posts
I see two available fans for your unit. The proper one is an AC/DC one which is kind of strange as it basically says 120v 6ohz on it.
Don't forget..... the fan only runs when the fridge door is closed.
Checking the fan supply wiring for AC or DC would be the next step.
Old 05-19-15, 07:24 PM
Tolyn Ironhand's Avatar
Received 786 Upvotes on 666 Posts
Also check to see if Evap coil is frozen up. Could be defrost heater.
