ge washer won't agitate
Old 05-30-15, 06:09 PM
I have a ge washer that trips the circuit breaker when it starts to agitate. I've replaced the belt but still trips breaker it spins and drains on that setting put soon as it fills and starts the breaker goes help please
Old 05-30-15, 06:14 PM
Tolyn Ironhand's Avatar
Received 208 Votes on 185 Posts
Welcome to the forums!
By breaker do you mean the circuit breaker in the electrical panel, or is it a GFCI receptacle with a "test" and "reset" button on it?
Old 05-30-15, 06:19 PM
yes the circuit breaker trips as soon as it starts to agitate
Old 05-30-15, 06:21 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Have you tested the washer on a receptacle on a different breaker?
Old 05-30-15, 06:25 PM
no but every other cycle works just not wash
Old 05-30-15, 08:37 PM
Is this a 15 or 20 amp circuit? Try running it on another circuit temporarily with an extension cord, preferably on a 20 amp circuit. If that breaker trips you likely have an issue with the washer, not the circuit/breaker.
Old 05-30-15, 08:59 PM
Received 1,110 Votes on 1,030 Posts
Can you post the GE model number.
One possibility is the timer is activating two windings at the same time.
Old 05-30-15, 09:44 PM
Sorry forgot to refresh the model # S2200Y0WW
Last edited by PJmax; 05-31-15 at 08:19 AM. Reason: corrected model number(O to 0)
Old 05-31-15, 06:08 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Please check model # not working
Old 05-31-15, 08:13 AM
F
Model number is valid. Remove front panel and try rotating motor pulley by hand in agitate direction. This would be CW looking down on it. It should be easy to rotate and this should cause the agitator to go back and forth. If it won't go, pull the agitator to see if something is jamming underneath it. If clear, then looks like a faulty transmission. Motor run windings on this model are selected by the speed switch, not the timer. The timer does select the polarity of power applied to the start winding so a faulty timer is still a possibility if you rule out the transmission as the problem.
Old 05-31-15, 03:27 PM
Pulled agitator out there seems to be a thin piece of wire or metal sticking up through the crease of the metal plate and the tub
