Roper Washer leaking water into tub
Old 05-31-15, 10:51 AM
Hi all,
My Roper washer is leaking water into the tub consistently. It's 24/7 whether it's running or not and if it's not been running for a few days, the tub is filled with water. I can see it's dripping from where the water enters the tub when you do run a cycle. I was hoping to try to fix this myself if it's at all possible. I believe the model number is SM 8525148-A (at least that is the only number I see when I open the lid). There is no leaking outside of the washer at all, it's all contained to the inside.
Thanks in advance,
Jamie
Old 05-31-15, 11:21 AM
F
Sounds like you need a new water inlet valve assembly. That's not the correct model number for the washer. There should be a label somewhere with model number and serial number, usually under the lid around the back of the tub rim.
