Old GE stove, timer keeps buzzing.
Old 06-06-15, 07:45 AM
N
I did a stupid thing and cut the wires to the timer/clock on my old GE stove without taking a picture of where those wires went to beforehand. Now my oven doesn't heat but the burners do. The good thing is, there is no more buzzing!
Can anyone help me reconnect the wires so that my oven works. I'd even put up with the buzzing if I have to.
I can't find any information on the stove that would tell me the model, only the information on the timer but searching for that turns up nothing.
Any help would be appreciated!
Size:  23.6 KBName:  IMG_20150606_102233117.jpg
Old 06-06-15, 09:53 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Post moved to more appropriate forum.
Old 06-06-15, 10:19 AM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
The white will remain capped as that was timer neutral which, by the way, is the only wire that you should have cut.
I need a new picture of just what I have highlighted below. The two wires circled in blue need to be connected. I'm fairly certain one is that heavy black wire but I can't read the other color.
Old 06-06-15, 12:08 PM
N
All the wires are black except the capped white wire (obviously). The two black wires on the left are coming from the dial (bake, broil, preheat, etc). The one on the right is going down into the stove.
Two of the black wires were some how attached before I cut them. I'm wondering if all three should be connected?
Old 06-06-15, 06:46 PM
Yes..... in looking at the wiring diagram again...... you can connect all three black wires together.
Old 06-08-15, 12:26 PM
N
I connected all three of the black wires and everything appears to be working now! Thanks so much for the help!
Old 06-08-15, 07:30 PM
You're welcome. Thanks for stopping back.
