Freezer not getting cold enough - GE TPX24SIYE
Old 07-06-15, 02:50 PM
N
Some foods were getting defrosted, temperature was about 10 degrees Fahrenheit in freezer. Noticed the condenser fan wasn't spinning, so I replaced the condenser fan motor but now freezer is up to 25-30 degrees. Sounds like the compressor is running but the coils underneath the refrigerator are room temperature (not hot, not cold). Before replacing the condenser fan motor I checked evaporator coils and there wasn't much frost on them. Defrost timer seems to be working since I can manually spin it and turn compressor/fans on and off. Just seems coincidental that right after I changed the condenser fan motor the freezer is getting warmer than when it wasn't working. A couple of times when I was first trying to figure out what might be wrong and I was restoring power the compressor did shutter for a few seconds. But it no longer does that, and after putting in the new condenser fan motor it didn't shutter. Any chance it can be something besides a bad compressor?
Old 07-06-15, 03:01 PM
Received 3,596 Upvotes on 3,225 Posts
If you're sure the compressor is running then it should be getting hot as well the condensor coils that the fan blows thru. If not..... you may have a refrigerant leak.
Old 07-07-15, 07:51 AM
N
Thanks Pete for the quick response. I know this might be a bizarre question, but by any chance would the fact that I removed the ice maker from inside the freezer have anything to do with it?
Old 07-07-15, 08:13 AM
I couldn't see how removing the ice maker would have any bearing on this problem.
