No ice from Kenmore refridgerator
Model 106.5654900
SS5124910
Kenmore coldspot ice maker is not working. No water in ice maker so no ice is being made. We have water in the door. Moveable teeth are pointed down. Tried unplugging and plugging back in and worked for a minute but stopped.
Any steps I can take?
Thanks
SS5124910
Thanks
Not sure about that model specifically, but you might try pulling off the plastic cover that faces you and look at the little plastic gears. Might be a broken one. Had that happen to a Kenmore we had many years ago. If the gear breaks the parts don't turn and the switches don't get engaged to fill, etc.
Please double check your posted model number.
You are a number short in the model number. Without the correct model number I can't help you.
Is it 106.56549400 ???
