Dryer tripping circuit breaker
Old 07-22-15, 04:05 PM
G
I have a whirlpool dryer that recently started tripping the circuit breaker after about 5 minutes of use. Now this only happens when the heat is on the dryer. When it is air only it does not trip the breaker. I have replaced the thermal resistor, the high limit thermostat and the cycle thermostat. It tripped the breaker again. The breaker seems good. Not loose, functioning correctly. Does anyone have any ideas about what could be wrong here? Could it be a different part in the dryer or could it be electrical?
Old 07-22-15, 05:11 PM
Received 3,594 Upvotes on 3,223 Posts
Welcome to the forums.
What size is the breaker that is tripping ? It should be a two pole 30A breaker.
If it is a 2P30A in place then you will need to visually check the heating element to see if it's touching ground. It won't be touching metal now but you should see burn marks if it was.
Old 07-22-15, 06:23 PM
G
It is a 30A breaker. But the thing is it worked fine for a year and a half before this started happening. And tonight it blew the breaker again and after half an hour on air only I switched it back to heat and it worked fine. This problem is intermittent.
Old 07-22-15, 06:27 PM
In the picture below is a typical Whirlpool dryer heater element. The element could touch the metal and short out when it gets real hot.
Old 07-23-15, 12:15 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Post model # and can give dryer pacific info. Weak breaker could cause this also.
Old 07-23-15, 05:39 PM
The model number will be helpful to us.
If you use the dryer.... and the breaker trips again.... see if it feels warm.
Old 07-23-15, 06:59 PM
ray2047's Avatar
Time for an Amprobe maybe.
