Dryer not heating or spinning
Old 08-02-15, 06:45 PM
K
Lightbulb Dryer not heating or spinning
I'm a little stuck here dryer stopped working about 10 days ago. I first replaced the Thermal Fuse and belt worked for one load of laundry then it stopped. Dryer will turn on and act like it is starting but then it won't heat or spin. I then replaced the thermister, another thermal fuse, thermst-fix, and belt switch; it did the same thing work for a load then stopped. Not exactly what else to do now?
Old 08-02-15, 07:15 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
We will need the make and model number.
Old 08-03-15, 07:57 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Does it make any noise, maybe a groaning noise when push to start button pushed?
Old 08-03-15, 07:24 PM
K
Whirlpool duet front loader Model Nimber wed9400ve0
It makes no noise just the normal button beeping noise.
Old 08-04-15, 12:34 PM
pugsl's Avatar
You will need a meter to test anything, Need to take lower panel off and behind lint chute there is a thermo fuse. Needs to show continuity. Also either in panel or tapes to inside side there is a tech sheet. Won't be to much help but will have wiring diagram that will help.
Old 08-04-15, 05:23 PM
K
We have replaced the thermo fuse twice now
Old 08-05-15, 04:11 AM
pugsl's Avatar
I bet you have long dry times also. Clean the vent to the outside. Way to check is take off vent tube from dryer and feel air flow, reconnect vent and go outside and feel air flow. Should be about the same. Vents are the #1 cause of dryer failure.
Old 08-06-15, 07:34 AM
K
The Vent goes to a box in the wall the other side of the wall is the garage there is no outside source.
Old 08-06-15, 12:56 PM
pugsl's Avatar
Has to have a outlet someplace, garage, roof someplace and must be clear.
