Stackable washer and dryer
Old 08-07-15, 01:33 PM
I want to put a washer dryer here. I know the outlet needs to be gfci but should I have someone lower the tap and cut down the drain so they are below the outlet?
Old 08-07-15, 03:52 PM
Received 343 Votes on 321 Posts
It customary to have the receptacle above the appliance so that it can be unplugged easily for service..... however the receptacle where it is... is ok too.
I can't see the floor in your picture but the drain line needs to be as tall as the washer to keep the water in the washer from siphoning out by itself.
Old 08-08-15, 06:57 AM
pugsl's Avatar
Received 21 Votes on 20 Posts
Drain pipe looks to low to me but can't see floor. Must be higher than water level in washer. Some washers will not work with gfci.
