Maytag Top-loader wash machine stopped
Old 08-27-15, 04:39 PM
My faithful old Maytag wash machine quit today.
It was mid-cycle when the water quit running. Now it will spin and drain, but it will not run water into the machine. What do I need to do?
Thanks in advance for your advice,
mama2_10
Old 08-27-15, 04:41 PM
Received 339 Votes on 317 Posts
Welcome to the forums.
The same problem with hot and cold water ?
Please post the model number of your machine.
Old 08-27-15, 07:38 PM
Sorry, meant to include that.
It will not run either hot or cold water.
Maytag Model #LAT9304AAE
Old 08-28-15, 05:40 AM
pugsl's Avatar
Received 19 Votes on 18 Posts
not a common problem but if i remember right there is a fuse in the white wire someplace, Forgot where it is but check it, May be hard to find, I think i found one behind front panel on right side in wiring harness.
Old 08-28-15, 07:44 AM
The fuse is part of the lid switch assembly inside the control panel. If it is blown, the lid switch is probably bad so just replace the whole assembly. The fuse will blow if the lid switch is stuck closed. The fuse is in the water fill circuit so the washer will not fill if it is blown. This basically prevents you from using the washer until you fix the lid switch problem.
Whirlpool 22001682 Lid Switch Assembly - AppliancePartsPros.com
Old 09-02-15, 11:40 AM
That was it! Many thanks
Thank you all so much. Between my teenage daughter and my husband, they got the fuse replaced and it works!
Unfortunately, merely dropping the lid caused the fuse to blow, so they've replaced it twice already. Need to find something to pad the lid so that it cannot "clang" shut.
Many thanks for your help!!! It's so nice to be able to fix it yourself instead of calling the repairman.
Old 09-02-15, 12:04 PM
pugsl's Avatar
Lowes or home depot in hardware have stick on bumpers that might work
Old 09-10-15, 05:37 PM
Agree, those places should have what you need to fix the issue.
