Amana Icemaker Line
Old 01-24-16, 12:38 PM
R
Amana Icemaker Line
The plastic line going into the icemaker won't stay in. It is just a slip=in line that goes into a rubber fitting and held in place with a squeeze clamp. Icemaker makes ice just fine, not hollow cubes, but some time after filling the icemaker with water the line just slips out. The fill valve seems ok as there does not appear to be any seepage after the fill.
Old 01-24-16, 12:41 PM
Received 1,112 Votes on 1,032 Posts
I could use the model number for your fridge.
Usually it's a metal tube that slides into a bushing. I don't recall a clamp holding it.
Old 01-24-16, 02:43 PM
R
Amana Icemaker Line
Thanks for your reply. Found fill line frozen at icemaker and know the input valve is leaking causing the problem. Replacing valve.
Not sure how to claim problem solved for this thread.
Old 01-24-16, 03:18 PM
Me either. The leaking valve doesn't explain the fill line problem.
If you need further help.... post the model number for me.
