Leaking kenmore elite dishwasher
I have a Kenmore elite dishwasher mod# 665.13963k014. It is not consistantly leaking, but mostly. I took the door gasket (around the tub) out and cleaned it. Made sure the water fill switch in the tub was clean with no soap build up, unit is one of 4 kenmore appliances I bought at the same time and having problems with all of them! . sorry off the subject. Can anyone help with the problem? Thanks
Temporarily Suspended
Maybe the gasket needs to be replaced. There is no reason to apologize, for stating that all 4 products are garbage. I consider it a public service announcement. You should too.
It is consistently leaking where ?
Under the unit or from the door ?
A clogged spin arm can also cause issues by directing water towards the door that would not normally hit there.
This is a help forum.... we don't trash companies here. There are sites where you can go and voice your displeasure.
When you say pin arm, is that located on the lower jet pin wheel ? Probably not the tech. name, but will the parts diagram specificaly name it? And also I would of replaced the gasket ,if the leaking was consistant. Thanks for the feed back!
