Whirlpool WH31S1E (small refrigerator) light works but cooling doesn't
Old 02-14-16, 09:31 PM
Received 2 Votes on 2 Posts
Just after the 30-day return period expired I noticed neither the refrigerator nor the freezer section was cooling.
The light was on so power was getting to the unit. I turned the dial all the way up, nada. Anything I can do to troubleshoot/fix?
A link to the unit with full specs is here:
Whirlpool 3.1-Cu. Ft. 2-Door Refrigerator/Freezer - BJs Wholesale Club
Old 02-15-16, 12:22 AM
Received 1,614 Votes on 1,486 Posts
When you turn the thermostat from OFF to maximum cold..... you should hear a click.
If you do..... the problem could be in the compressor or compressor wiring.
If you don't hear a click it could be a defective thermostat.
Old 02-15-16, 03:39 AM
GregH's Avatar
Super Moderator
Received 55 Votes on 51 Posts
In addition, you could pull out fridge and see if compressor is running and/or warm.
