Manual For Kenmore Microwave
Old 03-07-16, 06:34 AM
I am trying to find a manual for my Kenmore Over the Stove Microwave. It's model number is 665.85920992. I am sure it is at least 15 years old. I want to replace it but it is not easily observable how it is bolted up under my cabinets. Its was in the house when I bought it. I figure I would look at the installation manual but I can't seem to locate one.
Would anyone know a good site to download a copy of this manual?
Old 03-07-16, 07:05 AM
Received 25 Votes on 21 Posts
Any I've seen are bolted through the front of the cabinet above into the microwave.
Going to take two people to be safe.
Remove the screws, pivet the microwave down at the front and tap up on the back and it should pop right out.
Old 03-07-16, 08:44 AM
Received 340 Votes on 318 Posts
Joes instructions are correct.
Here's the installation manual for you unit... sears parts direct/download/OWNM/.pdf
Old 03-07-16, 10:48 AM
Since I will be acquiring a new microwave that will be about the same size as the old one, what do you think will be the chances that the bolts on the top cabinet out in front that go to the microwave and the screws in the back plate will line up with where the bolts and screws of the old microwave did.
Are these things fairly standard or is there not a snowballs chance of it being that easy.
Old 03-07-16, 10:53 AM
If it's the same manufacturer it could match but it's a slim chance.
Your old microwave was manufactured under Whirlpool.
Old 03-07-16, 12:10 PM
New one's going to come with a new mounting plate, just hold it up against the old one and see if they match.
There's also going to be a template for the drilled holes.
Old 03-07-16, 12:21 PM
Thanks for your help guys. Appreciate it.
