GE Profile PB975SP3SS range: one of the rings not heating
Old 04-30-16, 08:07 PM
I have a GE Profile PB975SP3SS range that's about 6 years old. It has a 3-ring element, and we noticed that the middle ring is not heating. Questions:
1. Is this a complicated fix? Does this require replacing a part?
2. Whatever needs to be done, can it be done without moving the range, i.e. accessing it from the front not from the back? The reason for asking is that if I remember correctly from our kitchen renovation, it was pretty hard to squeeze it between the two pieces of the countertop so it might be hard to move it out.
Old 05-01-16, 10:49 AM
Typically it's the element that goes bad but it could be a wiring or defective switch issue. You need to start by using an ohmmeter to check the element.
There are several elements used in that range. One of them is listed in the link below. There is a video in that link that shows how to check the element.
Radiant Surface Element WB30T10126 Repair Clinic
Always turn off electric to the range while working on it.
