Whirlpool side x side fridge damper
Model # GSF26C5EXW02. Motorized air damper wide open. Freezing food in fresh food section. Removed damper & hooked up jumper cord to it. Damper works fine, No power at plug where damper cord plugs into. Is thermistor bad? Or control board? What sends power to damper to regulate it? If thermistor, where is it located in fresh food section? Control board is very expensive. Want to make sure I replace the correct part. Thanks for the help! Dave
Dave.... I'm on limited access here so I can't give you detailed help.
But... do this.... pull the grill off the lower front of the fridge. Look around and up in there for a tech sheet. It may be rolled up or folded and in a bag. It's a mini service manual and will be very helpful to you. Do look around.... it IS somewhere on/in the fridge.
Doing a quick look around.... you need tech sheet #W10373993 in case you can't locate it under the fridge. You can also grab it here... forums/index.php?action=dlattach;topic=17702.0;attach=10559
(Download it and save it as I may pull the link from this post.)
