Repair Pantry End Cap
Old 11-17-16, 08:33 PM
I am not sure if this is the correct forum but this has been a neverending battle that I need help with. Both left and right pantry end caps which connect the sliding drawer are broken off. For reference, it is the plastic tab that holds the sliding drawer in place and is visible at 1:07 within this video: https://www.youtube.com/watch?v=wvqM2MrCNyo
The crack is horizontal at the base and is a clean crack which I have used monster and superglue which have temporarily worked. Should I try an epoxy? The glue would hold the plastic tab in place but then would loosen when I try to reattach the drawer. Any help is greatly appreciated.
Old 11-18-16, 02:42 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I've tried battling with plastic appliance parts, and find it better to replace the component rather than fixing them. This seems to be a pretty straight forward replacement. For $22 plus shipping, it may be a longer term fix.
Old 11-18-16, 05:52 AM
Handyone's Avatar
Gluing small plastic parts never works, there's not enough surface to make the glue hold. Even the original plastic wasn't strong enough for the job.
Old 11-18-16, 02:31 PM
You are right. I hate to replace the part over a small broken piece but that seems to be the better approach. I think I found the correct part but I am not sure because there are interchangeable parts from different manufacturers:
KitchenAid
Model: KFCS22EVMS3
Repair: https://www.youtube.com/watch?v=wvqM2MrCNyo
Parts
Whirlpool WPW10122078 Endcap - AppliancePartsPros.com
Questions and Answers for Whirlpool WPW10122078 Endcap - AppliancePartsPros.com
Part Number WPW10122078 (AP6015356) replaces W10122078.
Whirlpool WPW10121977 Endcap - AppliancePartsPros.com
Part Number WPW10121977 (AP6015354) replaces W10121977
