Maytag Washer out of balance on spin
Received 0 Votes
Replaced snubber ring as per Applance Pros YouTube. Still out of balance on spin.
Did you replace the 6 springs? Sometimes a little baby powder where snubber sits will help. I also have had to replace base to stop it but only once in many years.
Received 0 Votes
Maytag Washer Quiet Series 100 Model # MAVT546EWW Still Out of Balance
Did as Suggested. Replaced Snubber Ring, used Corn Starch, replaced 6 Springs. Still out of balance. Made sure Washer is balanced true. Is there still something I still need to do?
I have only seen this once 1 time we had to replace base. Before I did this I would look into a new washer. Part # to in base diagram
MAYTAG MAYTAG LAUNDRY Parts | Model MAVT546EWW | Sears PartsDirect
Major job and not sure it would fix your washer. How bad is it out of balance? Does the washer move across the floor or just wiggle?
Received 0 Votes
(P) HAV2557AWW Maytag 3 other sites recognize this # as a hoover??? noticed the balance instruc. on the lid. the side to side good but the front 2 back self won't act as needed. leaves me 1/8 to 1/4 off.
Received 0 Votes
took apart & all under parts look good & tight. no spring issues. can't really get into the back per say ( small opening) is there an easy fix to this. rental property used washer or easier to get another ? $$$ to used
You need to replace the springs and snubber. Parts are pretty cheap but a bear to install. Have done many of them'
here is a break down of washer, Look under base for part 18 and 29
https://www.searspartsdirect.com/model-number/hav2557aww/0517/0153200.html?searchType=modelSearch&q=HAV2557AWW&searchTerm=HAV2557AWW
Not common for this to happen on your washer. I would check that the springs are in place. They may need to be replaced but have never had to replace them. If I remember there are 3 of these springs.
