Frigidaire stove
Old 02-15-17, 03:42 PM
Frigidaire stove
The small stove burner gets red hot on any setting of dial. Research the forum they said it was dial so I swapped it out but still happens. Could it be the element then.
Thanks
Old 02-15-17, 03:46 PM
Received 1,114 Votes on 1,034 Posts
Welcome to the forums.
It could also be a shorted element.
Do you have an ohmmeter ?
You can disconnect the element and check each end or each contact to the metal tube.
You should not measure any continuity.
Power to range MUST be disconnected before taking anything apart.
Old 02-15-17, 04:52 PM
Thank you I will try that
