Dishwasher stuck on cycle
Old 06-13-17, 01:53 PM
X
Unhappy Dishwasher stuck on cycle
Hello all ok so my dishwasher is stuck on a wash cycle it is an old model Zanussi DS17 it hets the water and I can hear it cleaning
SO I cant tell if its the element The timer or the thermostat and I cant afford to buy all 3 parts
Can any one help me Figure out which part it is
Sam
UK
Old 06-13-17, 02:28 PM
pugsl's Avatar
Received 62 Votes on 58 Posts
Post model # This is manly a US site but will help if we can, With model # we may be able to see wiring diagrams but not usually.
Old 06-13-17, 02:40 PM
X
I'm sorry I didn't think of that,
ok from the Zanussi Mod DS 17 Prod.No. 911711020 Ser.No. 8120022 Type 91171-2a
If it helps if u give the timer Assembly a little shake should it rattle ?
Old 06-13-17, 02:45 PM
pugsl's Avatar
DW guys will be in later, most timers don't rattle. Sounds bad.
Old 06-13-17, 02:48 PM
X
Thanks, good old rattle test
Old 06-13-17, 04:34 PM
Received 924 Votes on 863 Posts
I'm guessing it's a mechanical rotary timer as I cannot find a picture of the timer.
Little to no tech support online for this brand as far as US accessibility.
Timer is the most likely problem. Good luck locating it. Seems everyone has the knob for it.
Old 06-13-17, 04:46 PM
X
Thanks buddie, yea seems to be the same problem here lots of knobs but no Replacement Timer, is there some type of generic timer I could fit in there ?
Old 06-18-17, 10:14 AM
X
So I don't know if this makes any difference in what's wrong but il still explain so the cycle starts normally but when it gets to the main wash cycle it gets stuck in the same place each time and the water gets very hot I have to turn the dial a few notches to get it to continue, is this still the timer or is it a bad thermostat ?
Old 06-18-17, 08:50 PM
I can't give you any specific help. I'd need to see a tech sheet or wiring diagram for your unit.
It is possible that your timer is delayed/held until the water hits a certain temperature.
Old 06-19-17, 10:43 AM
X
Ok I see what your saying
non specific do you think it would be a good idea to buy a digital multimeter and test the 2 thermostats on the dishwasher ?
