Front load washer not turning on - How to diagnose?
Old 06-24-17, 02:10 AM
E
Press the start button and nothing happens - no lights, no nothing. Prior to this, it was working fine.
Samsung front load wf0500nce
This is what i've done so far...
Using a multimeter, i checked...
Socket
Plug fuse
Power at the plug cable connector (which connects to the noise filter)
Power by back-probing the other connector of the wire that goes to the washer at the noise filter.
What else can i do to find out where the problem is?
The wiring diagrams: (can't upload here because of the ridiculous size quota).
https://i.imgur.com/pz0bapi.png
https://i.imgur.com/b72JVjs.gif
https://i.imgur.com/HFuXbIU.jpg
https://i.imgur.com/8PFzRkU.png
https://i.imgur.com/uazgBAy.png
https://i.imgur.com/j0w9neP.png
https://d3nevzfk7ii3be.cloudfront.ne...ZLYXAO2jpQXoVk
Old 06-24-17, 02:49 AM
pugsl's Avatar
Received 62 Votes on 58 Posts
In the wiring diagram there is a fuse in blue wire. Make sure you are getting 120 blue wire at board. Please check model # did not work. I think on your model control board and user interface are one piece. Going by memory and it is bad.
Old 06-24-17, 03:58 AM
E
@pugsl
I can't find/see the fuse, and there are several blue wires at the board. I've taken some pics.
https://i.imgur.com/CMPwT2X.jpg
https://i.imgur.com/7PE5ZJp.jpg
Model number is correct. There are also several other model numbers for same maachine depending on region. See below image for the other model numbers.
https://i.imgur.com/6o7T8nc.png
Old 06-24-17, 04:26 AM
D
Received 36 Votes on 29 Posts
[Just a quick note. Over the last day or so, there has been an issue with adding pics. Hopefully, this will get fixed shortly. Sorry for the inconvenience & thanks for your patience.]
Old 06-24-17, 05:05 AM
pugsl's Avatar
I found it in Samsung UK are you in US or out of country? Country LA?? is that LA county? Just found manual for your machine If in US it will not work. That is a 220 volt washer
Old 06-24-17, 05:56 AM
E
I'm out of the US. I got the service manual (wondering if the one you found is different). And i found the fuse, funny it says blue wire on the manual diagram but in actuality, its black. I tested it and its good. I'm getting 125v, even though power source is 220v, whats up with that? I also checked the black wire at the board and its showing 125v...but whats weird is it connects to a relay clearly marked "heater relay". I though the fuse would be to the power relay, which is what i'm supposed to be testing...what am i missing.
Old 06-24-17, 06:50 AM
pugsl's Avatar
Sorry I am not up on out of US wiring. by your pictures there is a blue wire is noise filter, I think it goes into yellow harness and than to board. That is the power wire.
Old 06-29-17, 03:02 PM
E
Anyone else?.....................
