Go Back  DoItYourself.com Community Forums > Household Cleaning, Kitchen Appliance Service and Repairs > >Electric< Large Kitchen and Home Appliances
Reload this Page >
Help Troubleshooting Frigidaire Dishwasher (No power to front control panel)
Old 07-03-17, 03:08 PM
L
Hello all,
I am having a heck of a time diagnosing my apparently dead dishwasher.
Here's what I have:
Model: FGHD2433KF1
Manuals:
Frigidaire Manual Search Results
Problem:
The unit is completely unresponsive. The front control panel appears as though there's no power and even if I push buttons, it won't cycle.
Here's what I've done so far:
Breaker appears fine, there's voltage to the main board and there's 12 volts at the door switch. I even replaced the main control board since I had a spare on hand and that did nothing (part # 154752901)
Now, if there's absolutely no power, it seems as though it's either the control board, the door switch or the panel itself. Before I spend $150 on a new control panel, I'd like to know if I can actually test for voltage on the board where the control panel would hook up.
The wiring diagram is wildly confusing to me and I can't for the life of me determine what some or voltage I should have running to the front control panel.
Any advice on how to properly diagnose this unit would be greatly appreciated. I do have a multimeter as well and a general understanding of electrical.
Old 07-17-17, 06:43 PM
L
Well....I was able to source a few used parts from another unit and tried swapping the control board and the control panel and still nothing.
Now i'm truly at a loss!
Old 07-17-17, 07:17 PM
Received 923 Votes on 862 Posts
Using the link you left. This diagram is from that.
You need to have 120vac to the door switch - white and black.
You need to have 120vac from the door switch when closed - white and black.
You need to have 120vac on the board at - P3-5 (black) and P3-6 (white).
When the door switch is closed you need 120vac at P1 (black) and P3-6 (white)
You can trip the door switch to close without actually closing the door.
