Whirlpool side by side refrigerator forming glacier in bottom of freezer
Old 07-11-17, 08:09 PM
okrobie's Avatar
It's slowly growing on the floor of the freezer and eventually pushing the freezer door open.
I think it has something to do with the Ice Maker.
Any help will be appreciated. Thanks, Jim
Old 07-11-17, 10:49 PM
Received 1,610 Votes on 1,482 Posts
Nothing to do with the ice maker. The condensate line is plugged.
You'll need to shut the unit off. Remove the back cover over the cold coil.
You may need a blow dryer to unthaw the ice.
At the bottom of the coil will be a tray with a 1/2" hole in it. This is the drain to the catch pan in the bottom of the fridge.
Some very hot water and a touch of bleach will clean the line.
You may need to use a small pointed tool to unplug at the top.
Go easy on the hot water as there is only a limited amount of catch tray and it will overflow with too much water poured down the drain.
Old 07-12-17, 06:50 PM
okrobie's Avatar
Thanks Pete. I didn't get a chance to mess with it today but tomorrow for sure.
Old 07-12-17, 06:56 PM
It's a common occurrence. A little time consuming to unthaw and clear the drain but should be fairly easy to do. I get a lot of those calls.
