Fisher & Paykel GWL15 washer stopped, one light blinking, others on
Old 07-27-17, 05:14 PM
I
Fisher & Paykel GWL15 top-loading washer stopped early in the cycle. Now, even if I turn it off and on:
- the leftmost orange washer light is blinking
- the 3 green rightmost lights are on
- the rinse and spin lights are on
- Warm, Auto, Fast and Regular lights are on
Googled it but could not find an explanation. I tried unloading part of the load but that didn't help.
What is wrong here?
Thank you!Name:  IMG_4397.jpg
Old 07-27-17, 05:33 PM
pugsl's Avatar
Received 60 Votes on 56 Posts
Have not worked on many but most needed a control board. Here is a service manual for your washer.
https://www.manualslib.com/manual/83...?page=4#manual
PS now would be a good time to get a real washer.
Old 07-28-17, 03:55 AM
I
Problem solved (itself?)!
All I had to do was wait. After about an hour, it magically started working again. I suspect it was probably overloaded which tripped some sort of sensor. It then "recovered" and everything went back to normal.
Old 07-28-17, 04:15 AM
pugsl's Avatar
Down load that manual you will need it.
