JT965SOK4SS GE Profile oven board needed.
Hello,
PJ Max (Pete) helped out tremendously last year on the issue of replacing bake and broil relays on my oven's PC board on this thread:
GE Profile Double Wall Oven JT965 - both bake and broil elements stopped working
I figured I'd be back at some point, as the foils on the board where I replaced the relays were burnt up and basically gone where a couple of the relay legs solder in. Now I just need to get a new board and need to make sure I have the correct part number? find out where the best place to get one would be?
Thank you.
Thank you.
Last edited by Dean Damron; 11-13-17 at 10:54 PM. Reason: Corrected title to better describe what I needed.
What happened...... the board fried. I've never had a repeat repair on any of my board repairs.
Anyway..... you need to check and repost the model number.
See post numbers 3 and 4. At any rate it appears that the JT965sK4ss uses the same board. The part number I found online for the board is WB27T10566. I was wanting to make sure this would work. From what I can see, it is identical. I will just purchase one.
Please feel free to delete this thread, as it is not really the type of content that helps a person make a repair, as it is too specific to my own issue.. I couldn't find a way to delete this thread.
Thank you again for your help.
Ok.... the model number is JT965SOK4SS.
Yes... the board you have listed is the correct one for your oven.
When you get the new board..... visually check the soldering quality at the relays.
As you've encountered..... this is an ongoing problem.
