Refridgerator in carport
Old 11-20-17, 03:15 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
My fridge when it gets cold outside (below 40) quits working. I understand the ambient sensor shuts it off. I was wondering if I but a light bulb in with compressor would this keep it running when cold?
Old 11-20-17, 10:15 AM
Received 1,113 Votes on 1,033 Posts
It's rare to find an ambient sensor on a fridge. It's more likely the liquid refrigerant is stalling the compressor. Keeping a small incandescent bulb next to the compressor will keep the liquid as a gas.
Old 11-20-17, 10:47 AM
Received 94 Votes on 83 Posts
I do have to ask - if it's below 40, who cares if the fridge isn't working since the ambient temp is going to keep the items as cold as the fridge would?
Old 11-20-17, 01:03 PM
pugsl's Avatar
This is a side by side and freezer items start to defrost.
Old 11-20-17, 01:32 PM
Received 319 Votes on 283 Posts
It's my understanding fridge/freezers made for exterior use have a heater of some sort to keep the refrigerant warm enough to flow. Adding a light bulb next to the compressor like Pete suggested might be the best you can do with that particular unit.
Old 11-20-17, 01:36 PM
OK, that makes sense - thanks.
Old 11-20-17, 02:43 PM
pugsl's Avatar
Light bulb added will see if it works.
Old 11-20-17, 04:08 PM
You can add a crankcase heater to the compressor with a thermostat if you are serious about your cold weather operation. The crankcase heater looks like a worm drive clamp and attaches around the compressor.
