Whirlpool electric dryer
Old 04-21-18, 09:34 AM
I have a whirlpool dryer Model wed4900xwo& it wouldnt run so I replaced the timer in it ,it had a burned out contact,after I installed the new timer I ran it through the cycles&it was running,but after I put it all back together,it wont run it hums & has a burning smell! Any advice on this will be appreciated!
Old 04-21-18, 10:39 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Did you put all the wires on the timer right. They are all labeled. Next tape down door button or have somebody hod it in.Turn dryer on Push start button and turn drum at the same time. If it starts you need a motor.
Old 04-21-18, 10:56 AM
2
Received 394 Upvotes on 343 Posts
May only need a new belt and not a new motor. The burning smell could have been from the motor pulley turning against a stationary belt.
Old 04-21-18, 01:52 PM
pugsl's Avatar
Did you pull the lint screen out when you were changing the timer? I have seen things dropped down there and jams the blower.
Old 04-22-18, 11:28 AM
Smile Whirlpool electric dryer
You were right1When I found the motor wouldnt turn I got into itfurther,I cleaned it out&lubed it hen got it to turn,then it jammed again,took back apart exhaust duct, it was very clogged&at the bottom the blower was stuckdue to a lot of debris in it,cleaned all that out&finally got it to work,to make a long story short $70 for a refurbished timer&a lot of labor it s working much better!Thank you for all of your help! Jim
Old 04-22-18, 12:53 PM
pugsl's Avatar
Be sure to clean vent to the outside or you will have other problems.
Old 04-23-18, 07:58 AM
Smile
Already vented! I replaced the old vent too!Thank u!Jim
Old 04-23-18, 12:37 PM
2
Did you check the belt to make sure there was no "burn' damage? Or was the motor jammed such that it could not rotate against the belt?
Old 04-23-18, 01:50 PM
Motor was jammed couldnt rotate!
