Kenmore front load washer leak
Old 04-30-18, 09:20 PM
K
My kenmore Front Load 970L48422E0 washer is leaking from a siphon hole atop of the housing dispensor. It is located after the valve dispensor. Any ideas why. It leaks down onto the drum.
Old 05-01-18, 05:45 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
worked on those washers for many years I am lost. Don't know what you are talking about. What siphon hole? What valves ? Did you take top off and looking in there? Most times a leak from top is that you are using the wrong soap< MUST USE HE SOAP. or you are using to much soap. I always said to use /2 of the amount recommended.
A picture of area would help.
How to insert pictures.
