Frigidare washer
Old 05-14-18, 04:13 PM
Frigidare washer
Greetings, we have a Frigidare washer that rumbles in the rinse cycle, no matter what size load is in there, no problem with spin cycle when there is nothing in there.
Geo
Old 05-14-18, 05:12 PM
pugsl's Avatar
Post model# so we can see what washer you have. Are you sure it is not in spin cycle? Most noises are in spin.
Old 05-14-18, 05:29 PM
Maybe it's your clothes washer trying to compete with the furnace for the most noise.
Old 05-15-18, 04:53 AM
Sorry ,mdl. FTF530FS1 and I must be loosing it ,itís the spin cycle, Pete if there is a competition this washer is winning!
Geo
Old 05-15-18, 03:34 PM
pugsl's Avatar
I know that washer well. You have a bad bearing. It will need a rear tub and basket assy. Basket assy usually warrantied lifetime and tub 10 years. In recent years the warranty was changed to 1 year on everything. Check our owners manual to find out what you have. Repairs cost upward of 600 dollars. Warranty no mater which you have does not cover labor.
Old 05-15-18, 03:41 PM
Hummmmm, I guess we run it until it stops bearing.
Geo
Old 05-16-18, 03:19 AM
pugsl's Avatar
Lift the basket in the tub If more than a 1/4 inch of movement you are not to far from the end.
Old 05-16-18, 08:57 AM
Lift the basket in the tub, do I do that by reaching in from the front or does the top pop up?
Geo
Old 05-16-18, 01:48 PM
pugsl's Avatar
Reach in the door and just lift the silver part.
Old 05-16-18, 04:06 PM
Now what? There is no play in that drum.
Geo
Old 05-16-18, 05:34 PM
pugsl's Avatar
You usually have a few months left if all if is doing is roaring. If you turn drum by hand you will feel how rough the bearing are, Did you check your warranty?
Old 05-16-18, 05:42 PM
Bearings feel fine when I spin the drum, If I pop the top would I be able to see anything else by looking in there? Did not check warranty,if labor is not included what is the use, cheaper to buy a new machine.
Geo
Old 05-17-18, 05:17 AM
pugsl's Avatar
Taking top off will just show white tub and a few components. Just in case can you post a video with sound so I can hear the noise. If a roaring in spin it is the bearing. Labor 200 to 250 before I retired 5 years ago don't know now. New machine 700 up. Worth calling Frigidaire to find out. Need model and serial #'s when you call.
Old 05-20-18, 02:11 PM
Hi Pugsl, no warranty machine was built in 2007 , I have a video I will try and post.
Canít post the video as it is to large.
GEO
Old 05-22-18, 06:24 AM
Hi pugsl, do these parts go anywhere inside or are they shipping parts that were left inside?, how do I check the shocks ? I removed the bottom pin and the shock seemed to have tension, as for the springs what should I look for?
Geo
Old 05-22-18, 02:13 PM
pugsl's Avatar
Those are shipping bolts. Surprised they are inside. Shocks have a replacement kit but I never changed them unless broken. Springs are hard to tell anything about them. Only reason to change shocks and springs is if washer is walking across the floor. Not for a noise.
Old 05-22-18, 02:52 PM
OK, Thanks I thought they were shipping bolts but thought I would ask, itís not working around yet, I hope to get more into in a day or two.
Geo
Old 05-26-18, 10:42 AM
Update on washer noise, after removing the top and front bottom panel I checked shocks, springs , and ran washer with a full load no cause for vibration or noise could be found ,i reassembled while running and all is fine.
Geo
