identifing a kenmore washer
Washer died.
I know kenmore didnt build it.
Looking online, it appears to be a whirlpool.
But, i am unable to identify which whirlpool so i can get a repair manual and/or seek help on here.
I have the original sales reciept, so i know how old it is, model number tag is readable.
Anybody know of a way to identify the whirlpool model?
The models i see online do not match mine.
The console on top for the controls appears to be attached with two screws in the front, one in each lower corner and two screws on the rear top . one in each corner. The rear screws seem to be attached to a black plastic tab that runs for about 1"inch inside the console, then a tab sticks out through the cabinet.
I can post photos, if that helps.
Thanks for whatever help you can give me.
Model # on Whirlpool are under the lid in back. There is a tag with model and serial numbers. Lift lid and look under back. If Kenmore usually starts with 110.xxxxx
Model
110.8287012
Stock
28701 there might be a 1 or 7 at the end.
Serial
C9485018
Purchased
11/28/89
I assume the kenmore model number is not the same number as whirlpool uses.
I need to know what whirlpool calls this washer so i can get a repair manual
Thanks.
110.8287012
Stock
Serial
C9485018
Purchased
11/28/89
Thanks.
Incomplete model number..... could this be it. 110.82870120
That's the basic direct drive Whirlpool machine. Great performer.
What's the problem with it ?
That may be a L-55 series. Pugsi would know.
This should be your machine... L-55-washer-manual/
Typo, sorry.
110.82870120 is correct.
I will take a look at that manual and see if it is the right one.
It filled, agitated. Then it would not drain or spin. It would hum, like something was trying to move, then click and try again in a minuite. Like an auto reset circuit breaker tripped because of a jam, reset, then trip again.
Plug was getting warm so i unplugged it.
Agitator seemed to be slipping lately. I assumed something wore out but i didnt get a chance to check it.
Not sure if the two are related. I suppose something could have broken off the agitator and jammed the drum.
Hasn't needed service for 29 years, so i assume i will be replacing a few parts while i have it apart, not just whatever broke.
Thank you.
Thank you.
That is one of Whirlpools best made machines. I have a similar one. Same vintage.
The motor runs in the forward direction to agitate. It runs in the reverse direction for draining and spinning. I'd start by unclipping the pump off the motor and try that.
That agitator uses 4 nylon pawls called dogs. They allow the agitator to turn in the forward direction. If you have never replaced them.... they need it. A very simple repair.
A video demo..... you tube/watch?v=kJ_HIlJULhw
If motor hums in either wash or spin usually something stuck in water pump. (usually a baby sock or woman's underwear.) Lean washer back against wall and unclip pump form motor DO NOT REMOVE HOSES AT THIS TIME) slide pump off shaft , put washer down and try a spin cycle. If washer motor runs than you will need a pump.
I use a wet dry vacuum to get water out of washer. I also have that machine it is 18 years old and do not plan on changing it anytime.Repaired washers for over 0 years and best washer ever made.
I did not look at manual as that washer has been used for many years and all are worked on the same way. There will be some differences in some parts, mostly the controls. Did you try what I told you to do?
I double checked that manual. It's not an actual service manual...... it's a training manual but it will cover your machine. It also covers mine.
The transmission-motor-pump come apart in three pieces.
Two snap clips hold the pump onto the motor.
Ok thanks.
I have not had time to do much with it yet.
Followed the instructions and opened the console,found out what the plastic things on the back are. Hinges.
Disconnected the lid switch harness.
Popped the clips holding the cabinet together.
Tomorrow i should be able to start working on it.
Parts breakdown....
sears parts direct/11082870120
Part #22 under Brake, Clutch, etc. tab.
OEM drain pump part # WP3363394
Do a search for that part number.
I like Sears parts. They have the best online parts breakdowns and visual help.
However.... their prices are not always current. You could check with them first to verify.
There are other reliable retailers that back their parts up....
repair clinicl/Drain-Pump/WP3363394/3296
appliance parts prospump-assembly-wp3363394
i will check on the sock, or whatever is stuck, and on the other suppliers you mentioned.
but right now, i am trying to get to the dogs you mentioned.
i have the cabinet off, and the auger and agitator off as one unit. i cant separate them.
parts direct diagram shows nothing holding them together, the manual you gave me shows a second cap and my auger looks like it has a tabbed washer at the bottom of the auger.
i figured i would check before i guess and break it.
#21
also, there is a lot of scum built up on the tub, under the agitator.
i can easily clean it now, but is there a way to clean it without taking it apart?
just wondering if there was an easy way to prevent the scum from building up.
#22
I left you a video link back in post 7 on the dogs replacement.
Affresh for clothes washers is a good cleaning solution.
They also make an excellent cleaned for dishwashers.
#23
You don't have to take agitator apart to replace dogs. Just the upper part where the bolt goes in. That agitator is a hard one to come apart. I usually stand on bottom part and pull the top part off. It snaps on but there is no reason to take apart.
#24
thanks for reminding me about the video. and the cleaning suggestion.
next problem, i took the cabinet off, took the pump out, pump is not clogged and spins freely.
is it possible something jammed the pump and worked itself free when i took the pump out?
is there an easy way to test the pump while i have it out?
would it be worth it to put it all back together and see if it works, before i replace the pump?
#25
Clip pump on motor, either jump lid switch or slip cabinet on and plug switch in and try it. no need to put all together. You did not take basket out did you?
#26
basket is still on. only took the agitator out.
if i try this and the pump works now, do you think i should still replace the pump?
i mean, how long do the pumps last?
this one is 29 years old.
i am going to do as you said and clip it on and try it, just to make sure it is not something else that is wrong. after all, i have no idea what i am doing. but if the life span of the pump is 20 or 30 years, i should probably replace it while i have it apart.
#28
clipped the pump on, turned it on in spin, pump spun, but the basket moved slowly and made a rubbing noise, like it was hitting something.
that might be just because it is out of alignment, the cabinet is off.
so, pump problem is fixed. maybe the hard water jammed it and it broke loose.
could my problem be the electric motor? is there a way to test it?
#29
If the motor runs it is good. In many years of repair only changed about 4 motors.
Basket turning slowly look in cabinet about 6 inches up from floor. Is there a streak of oil? If there you need a top seal for gearcase and clutch. While there replace drive coupler.
#30
Not sure what you mean by "streak".
If you mean a narrow strip, no.
I do have , what appears to be ,a thin film of of an oily/greasy substance about 6" wide, starting at the floor, on the two sides of the cabinet.
6" high might be a better description. From the floor, 6" up the cabinet.
Is that what you meant?
#31
Oil around inside of cabinet about 6 inches up is a leaking seal. Seal is a couple of bucks, clutch was about 30 but I haven't googled prices in a long time.
Google Whirlpool gearcase repair and many videos are there on how to do.
What happens is seal leaks and oil goes up shaft into the clutch and than clutch slips. Also throws oil around inside cabinet. Replace drive coupler while apart.
#34
gear case is out, top cover is off.
most of the oil is still in the case. about 1/2 to 3/ 4 full.
any chance it is not the top seal?
something is leaking, but i expected to find the gear case empty.
should i try replacing the top seal? see if that fixes it?
if i replace the top seal, clutch, oil, drive coupler and dogs, is there anything else i should replace while i have it apart? is there any other parts i should order?
#36
parts were ordered, trickling in, very slowly.
while replacing the brake cam on the drive tube, i saw, what looks like, a twisted, broken gasket.
but, it doesnt appear to be attached to anything, or ever was. only one spot is dirty. i cant find it on the parts diagram.
does anyone know what it is, where i can buy a new one, what does it do and what does it connect to?
photos are, hopefully, attached.
#37
Not a gasket I can only guess it was some sort of sound dampener. Don,t worry about it. Most are like that.
Throw away.
Throw away.
#38
Been waiting 6 weeks for parts.
Guess it is time to give up. Guess whirlpool has better things to do.
Is there a gasket sealer for the cover on the gearcase that i can buy locally? Like an automotive gasket sealer?
I got the other parts, but i guess gasket sealer has to be hand made in Pakistan and delivered by mule.
