KitchenAid dishwasher not starting
Old 05-25-18, 01:35 PM
C
I have a relatively new KitchenAid dishwasher model KDFE304. It has a series of LEDs across the top to indicate status.
My dishwasher will not run. The dishwasher has water, the overflow float is not blocked (it is all the way down), I cleaned the filter and the door is fully closed. The CONTROL LOCK button is not selected (the LED is not on..
But still it won't start
When I press the START button, all the usual LEDs light (Pro Wash, START, Add dishes and WASHING).
After about 30 seconds all the LEDs go off - except the CANCEL LED, which comes on.
It doesn't do anything more. I recycled power as well. Still no luck. What could be wrong?
Old 05-25-18, 04:40 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Take off kick panel d there should be a tech sheet in there. Follow directions to get into diagnostics.
Old 05-25-18, 07:19 PM
Received 4,051 Upvotes on 3,634 Posts
This link should be to your tech sheet. Please download it and let me know when you have it as I will then remove the link.
Tech sheet # W-10543820
