Got a new stove!
Old 06-04-18, 12:09 PM
trish69's Avatar
Post Got a new stove!
Hello All - I recently purchased a stove from my neighbor but the wiring is different from that in my junction box. The junction box has 4 wires, while the stove only has 3. Does the 4th wire in the junction box have to be connected or can it be capped off?
Old 06-04-18, 12:54 PM
Received 857 Upvotes on 749 Posts
Welcome to the forums!
I suspect you need to replace the plug/wire like you have to on some dryers. But I'm just a painter, those that know more about stove/wiring should be along later.
Old 06-04-18, 08:42 PM
Received 4,052 Upvotes on 3,635 Posts
Mark is correct. If the appliance has a three wire cord it will need to be replaced.
Usually the cord needs to match the receptacle.
You mentioned junction box. Are these cooktops ?
They usually connect to a junction box.
A range should use a cord with plug and a matching receptacle.
Old 06-05-18, 03:22 AM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Where the cord connects to stove there is a picture of how it is wired. If missing we can help.
