Rewiring for Whirlpool Range RF386PXEN0 stove glass top
Old 12-05-18, 09:23 PM
Hello, I have a Whirlpool Range RF386PXEN0. I need to rewire the glass top burners, I went to turn it on and the 4th of July came early, sparks, smoke and everything else. I turned off the breaker, lifted up the top, and found a smoldering mouse under the burners. It ate through some of the insulation and outer wire insulation After dinner (yes it does taste like chicken). I looked for a replacement wire harness but it is no longer available. Can I use awg12 High-Temperature Heater Hookup Wire TGGT Appliance Grade? The original wire is Radix 12 AWG Wire Type SF-2 SEW-2 . I can only find it in 100' or more lengths and it is rather expensive, I only need about 24' maybe 30' at the most. Any advice would be appreciated, thanks.
Old 12-05-18, 09:42 PM
Received 3,183 Likes on 2,858 Posts
TGGT wiring is fine. The SF-2 SEW-2 is like 200C and the TGGT is 250C.
Be careful if you are splicing. You'd need ceramic wire nuts.
Old 12-05-18, 09:52 PM
thank you very much for your help and quick response.
