clear drain line sears kenmore refridgerator
Old 12-06-18, 07:36 PM
tsnider's Avatar
I was trying to help my son clear the drain line from a Sears Kenmore Elite refrig. # 795.7401 side by side with a bottom freezer. You tube videos haven't been helpful. We can't figure out how to get to the line. Can someone point us to a service manual?
Thanks
Old 12-06-18, 07:40 PM
Received 1,113 Votes on 1,033 Posts
You missed a few numbers in the model number.
Old 12-06-18, 07:50 PM
tsnider's Avatar
k just assumed their written down number were correct. I'll get the full number
Old 12-06-18, 07:51 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
This might get you closer.
https://www.searspartsdirect.com/mod...tml?q=795.7401
​​​​Or a manual from a similar model might help you figure it out... https://rice360.wildapricot.org/Reso...r%20Manual.pdf
Old 12-07-18, 12:07 PM
tsnider's Avatar
The full number is 795.74013.411
Serial number 605kr00152
The frig builds up water and ice on the bottom shelf of the frig. I'm assuming the drain hose needs be to unplugged. How is the hose accessed from the frig unit in front or through the bottom in back of the unit? We were trying to get at it from the front and ran into a roadblock pretty quick.
It looks like the center column and lower left quadrant of the frig back is a single unit. After removing the single visible screw the piece still doesn't budge. There are 4 tabs on the column. I didn't have a putty knife so I couldn't get them loose.
We're assuming access is easy once the secret is known.
Old 12-07-18, 10:53 PM
I don't work on many LG's fridges. The diagrams are not clear for panel removal. There are many videos on you tube you can look at. Put in "replacing LG evaporator motor".
The link below is the exploded view of the insides. The problem is most likely in the bottom center of the drip pan.
312C drip pan
308A drain pan
click on diagram for expanded view
See Case Parts tab
Sears Parts Direct LG fridge
