Kitchenaid dishwasher error codes
Old 03-02-19, 07:15 PM
B
Am not able to get my Kitchenaid model KDFE104DSS dishwasher to reset. Looked online for how to enter the sequance using the temp and dry touch pads but nothing works. Unit is 4 years old and ran perfectly until now.
Old 03-02-19, 09:23 PM
Received 1,612 Votes on 1,484 Posts
Welcome to the forums.
Have you tried disconnecting power to it for a minute or two ?
There will be a tech sheet behind the front kickplate. It may be folded up and in a small plastic bag. It will give instructions for resetting the processor and putting it in test mode.
If pushing the buttons doesn't seem to do anything..... or the wrong function is happening..... or random lights are coming on..... that would indicate a defective keypad which is very popular Whirlpool dishwasher problem.
Old 03-03-19, 04:06 PM
B
Thank you. Found the tech service sheet behind the kickpanel as stated. After reviewing its contents and initiating the diagnosis cycle I was able to pull codes 7-1, 6-6, and 6-4 which was related to the Float Switch and was revealed after it ran a diagnosis cycle. Will read more about confirming if its bad or something else.
