Kenmore Fridge Randomly Shutting Off & Turning Back On
Old 04-11-19, 05:08 PM
G
I have a Kenmore Elite Fridge. Model 596.78576803
The past few weeks, itís been randomly shutting off (no cooling, no noise, no lights, no LED temp displays) a couple times a week. We can fix it 100% of the time by just opening the fridge and waiting about 5 seconds and everything will come back on and it begins to cool. Our fear is that if we donít open the fridge, itíll just stay off and all our food will go bad. Any suggestions on what might be wrong?
Old 04-15-19, 10:21 PM
Received 1,103 Votes on 1,023 Posts
Welcome to the forums.
I didn't want you to think I was ignoring you. I've been trying to determine what could cause your problem. Typically it would appear to be a problem with the control board on the back of the fridge. That board has been known to go intermittent or fail but opening the door doesn't usually affect it. Unplugging the fridge for a few minutes would reset the logic which may or may not help.
There should be a tech sheet either behind the kick plate or in the back by the compressor if there is no kick plate. It will be folded and in a small plastic bag. It should have a diagnostic routine you can run the fridge thru that may pinpoint a problem.
Old 06-30-20, 12:51 PM
W
I had the same problem but unplugging the power did not help to solve the problem. At the moment, no display and no running at all. The only thing work is the cabin light when open the door. Any idea or suggestion?
Questions:
1: Where is the a AC fuse for the Kenmore Elite fridge model # 59678532801?
2: I am looking for the service manual for this series of Fridge. I am low income and needing to fix it myself. can's afford to buy new one.
3. Any one has the circuit diagram for the control board (W10310240A)?
Thanks in advance!
William
Old 06-30-20, 04:56 PM
Kenmore by Amana and made by Whirlpool.
I'm showing WPW10317076 as the control board for your fridge.
Did you look under the fridge for the W10279334 tech sheet.
Sears Parts Direct
There will not be a schematic for the control board as it is proprietary property.
You can buy a service manual. $14.95 with digital download..... Service manual.
I'd imagine your problem stems from a problem on the control board. If I was servicing it I'd put scope on the HV section and watch the power supply. As a generic repair..... replace all electrolytic capacitors as that is the #1 power supply board failure problem.
