LG Washing machine issue.
Old 04-22-19, 05:10 PM
Model #WM2233HW
So, when you press the POWER button, it makes a chime type noise. After that, nothing lights up, unable to select the type of wash and unable to select start. Any advice? Thank you.
Old 04-22-19, 05:52 PM
Received 1,119 Votes on 1,039 Posts
The first thing to try is unplugging the washer for a few minutes and then check it.
Old 04-22-19, 05:54 PM
Ok, I'll give that a shot when I get home. Hopefully, that's the issue. If not, I will report back. Anything else to look for in case that's not it?
Old 04-22-19, 06:20 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
Looking for a tech sheet for your washer. Could be a button stuck or main cpu. I replaced .quite a few of each before I retired. The tech sheet will tell you how to get into test mode. PJMax has better luck finding sheets than I do.
Old 04-22-19, 06:37 PM
The service info in the link should be helpful...... LG service information
Old 04-23-19, 04:01 AM
pugsl's Avatar
Thanks Pete..................
