Craftsman Handle AC-0002
Old 05-19-19, 02:37 AM
A
I purchased a used craftsman 25 gallon air compressor (919.165250) which is missing the handle (part AC-0002). This part is no longer made. What can I use as a replacement part?
Old 05-19-19, 02:52 AM
Received 321 Votes on 285 Posts
I'd put on my thinking cap and just make one. It shouldn't be too hard, all you need is some stock that will bolt up to the compressor on each side and then connect together on the other end with some sort of handle. You could also bend some round stock and make one similar to the factory handle but that might require more skill/tools.
Old 05-19-19, 02:55 AM
A
I was just wondering if there is a pre-made handle that will do the job.. From a similar compressor.
Old 05-19-19, 03:04 AM
It's quite possible, the main thing would be having the bolt holes line up.
