Where is the water reservoir?
Old 06-28-19, 08:10 PM
Received 4 Votes on 3 Posts
I'm attempting to replace the water reservoir on a Fridigaire side by side and can't find it for the life of me. It isn't behind the drawers where I expected it to be. I followed the water lines from the valve into the fridge, and they go straight up to the filter at the upper right, then back down to the bottom, out of the fridge and across the bottom, then to the front and up to the water dispenser in the door. Is it possible there is no reservoir in this fridge? The part that matches the model number is the cylindrical coiled type. I see it in the diagram on Sears.com but I swear it is nowhere to be found. Model# of the fridge is FGHC2331PFAA.
Old 06-28-19, 08:41 PM
The previous owner must have removed it because it is not there. I can see the mounting holes for it and someone siliconed the hole going through the bottom of the cabinet. Ridiculous.
Old 06-28-19, 09:12 PM
Received 1,345 Votes on 1,243 Posts
Removed it to make more room for refrigerated stuff ?
Old 06-28-19, 10:09 PM
No, because it sits behind a cover for the light.
Old 06-28-19, 10:26 PM
Ahhh.... then it leaked and they didn't want to spend for a replacement.,
