Whirlpool freezer issues
Old 07-19-19, 06:41 AM
H
If you search WRF990SLAM, you will see some of the myriad issues with this thing. If I weren't planning to move in 4-5 months, I'd replace it (people usually don't take fridges with them down here).
Anyway, WRF990SLAM00 wasn't freezing properly. Looked like the drawer may not have closed completely and there was ice build up. Dealt with that in the past so not a big deal. Put everything in the chest freezer and left the drawer open to defrost overnight. Did not turn off cooling as that would have required emptying the fridge at 10pm. Anyway, this morning the ice build up appears to be gone so I close the drawer. In the past, I wait a few hours and it gets back down to temp no problems. Today, that isn't the case. It's cooling very slowly, if at all, and it's doing a six chime beep with 10 clicks every 4 seconds. This is completely new behavior. Only thing that makes it stop is to open the door. I assume this is the temperature alert and that it will only go away when the temp regulates. I can't find anything else to tell me how to make it stop.
Is this the temp alert? Is there a way to make it shut up? Will putting some frozen things that I can just throw away later in the freezer help it get to temp faster?
I'm giving it another hour to see what the temp is to make sure it's actually cooling unless I hear something sooner.
Old 07-19-19, 07:12 AM
H
It appears it was the temp alert and it was going off like that because of extreme temp. I put a frozen water jug in there and the temp on a fridge thermometer is now showing below 40 and the alert stopped. So not down where it needs to be yet, but at least it's not beeping every 4 seconds.
