Spindle/shaft for an LG washer #WM2101H* or compatible
Old 08-18-19, 03:20 PM
I might have ruined my spindle/shaft while trying to dislodge it from the drum assembly. If you have a spindle/shaft (the part that protrudes from the spider) for an LG Washer Model #WM2101H* or Compatible Models, I can use it. Please post a reply on how to contact you or- if the diy site has a private message feature -send me a message through the diy forum and I'll get back to you. Thanks in advance!
Old 08-18-19, 04:21 PM
Yes, I'm aware of that. I'm trying to find someone who will sell me the part for significantly less than what I'm seeing out there : )
Old 08-19-19, 04:39 AM
pugsl's Avatar
Received 18 Votes on 17 Posts
Since you have the tub out did either the front or rear 1/2s have any damage. I have seen them all torned up.
Old 08-26-19, 05:44 PM
Pugsl,
My apologies- I just saw your message. Anyway, what are '1/2's'?
~hlpmehlpmyprnts
Old 08-26-19, 05:51 PM
pugsl's Avatar
I was asking about the front or rear haft of the tub was damaged. Happens a lot when bearing go bad.
Old 08-26-19, 09:13 PM
The tub doesn't appear to have been damaged at all. The top of the shaft/spindle is damaged, but the spider itself is fine. I'd like to just be able to get a new spindle/shaft without having to get the entire spider as well.
