samsung fridge
Old 09-20-19, 11:25 AM
samsung fridge
2015 samsung model rs25h5111bc fridge. freezer woeks fine fridge at 57 degrees. and holding. fast forward 2 days, just for no reason i unplugged it and plugged it back in late one night. next morning it seemed to be working ok. also there was a puddle of water on the floor and in the bottom of fridge. so the question is should i cancel a service call for next tuesday thanks for any advice you can offer
Old 09-20-19, 12:44 PM
Received 1,113 Votes on 1,033 Posts
Sometimes all it takes is to unplug an appliance and then plug it back in to reset the electronics.
How long was it off ?
Water in the fridge and on the floor would probably be from condensate when the unit defrosted. Water inside the fridge could possibly be a plugged drain. As the unit defrosts.... the water goes thru a drip tray under the coil, down a short hose and empties into a condensate evaporation pan. If you're in a high humidity area.... the tray in the bottom could have been quite full and sloshed around when you moved the fridge.
If your fridge temperature starts climbing again.... you may need to check into a possible defrost issue.
Old 09-20-19, 02:24 PM
thanks pjmax i plugged it back in instantly after i unplugged it.
Old 09-20-19, 02:26 PM
All you can do is watch it. The reset may have triggered a defrost cycle.
If you see water inside the fridge then it could possibly a plugged drain line.
