Dishwasher arms not spinning
Old 11-10-19, 10:11 AM
I have a Whirlpool Gold series dishwasher that has 3 arms. The bottom and middle are not spinning but the top one is. I've cleaned the arms and the sump area and filters with no results. I removed the upper rack with the middle arm attached and ran water from a garden hose thru the tube and while water shoots out of the arm holes, it still doesn't spin. Does anybody have any other ideas I could try.
Old 11-10-19, 11:07 AM
Received 1,525 Votes on 1,408 Posts
No model or age listed.
Typically that's cause by reduced output from the main wash pump which is usually caused by a blockage into the pump.
Old 11-10-19, 11:14 AM
Thanks for the reply PJmax...The model is wdf750sayw1 and I purchased it in 2012. Is the main wash pump the same as the circulator pump?
Old 11-10-19, 11:38 AM
Norm201's Avatar
Received 356 Votes on 321 Posts
Have you periodically removed and cleaned the tub screen/filter?
Old 11-10-19, 11:45 AM
Yes, I do that every few months. I have never had much on the screen or in the filter
Old 11-10-19, 01:02 PM
Received 164 Votes on 151 Posts
Do you have the tech sheet?
It is usually behind the kick plate
Perhaps the following will help.
https://www.dropbox.com/s/2ngwlh135q...asher.pdf?dl=0
Often a low fill van cause this.
Check that it is getting enough water.
If in doubt add some hot water just after a fill.
Also this unit uses a diverter that can cause problems.
Just be careful not to overfill it.
Old 11-10-19, 01:19 PM
The water level is at the bottom of the heater element so I figured it was correct. I didn't realize that it had a diverter so I will look into that further. Thanks for the info and link Manden.
