Washing machine won't start: outlet ?
every time i have to start washing machine, i have to pull my cord from the outlet and insert again
then it sparks and works for one wash, then it dies, again i have to pull and insert and works
while inserting the cord, i see a spark
i am using same outlet for other application such as work light, and it works fine
can someone guide me - what is the issue and how to fix it
thank you
thank you
Hello
I moved your thread to the appliance forum.
Your problem is with the washer. Every time you unplug it your are resetting the processor.
We need the make and model of your washer.
very many thanks
i was under impression that issue is with my outlet being old
make: LG
model: WM3470HVA
it is about 6 years old
will appreciate your further guidance
thank you
make: LG
model: WM3470HVA
thank you
I would start by plugging washer in a different outlet. Use a heavy duty extension cord if no other outlet near. Your LG had control board problems. I retired about the same time your's came out so don't know if that problem was fixed. I had never run into your problem. If outlet feels loose when you plug it in it could be your problem but would try other outlet first. A 15$ investment in a good extension cord is worth it. Get a cord that says wire size 12 or less. Smaller number is better in this .
Does sound like a control board problem.
These units also had problems with the electrical noise filter so I would also take a look at it.
very many thanks
when switch on/off my circuit breaker, it works for one wash and then again it dies
can you help further how to do further diagnostic ?
do you know how to reset the control board / panel - would this help ??
best wishes
best wishes
Here is a service manual for your machine Page 17 starts diagnostics
https://www.appliancefactoryparts.co...s/125458-8.pdf
No reset for that board other than what you have been doing.
